Old 07-12-2013, 11:16 AM
Mainecubcadet108's Avatar
Mainecubcadet108 Mainecubcadet108 is offline
Default Compresion spring length
What length should a read spring be compressed to when using a split collar.I heard it should be at 4 and a half inch when compressed.Does that sound right i may be wrong
thanks
Current tractor my son and i have
1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp
1980 whelhorse b-82 need restore
1976 simplicity 7116 all restored waiting for a new motor (my sons tractor)
1967 sears super 12 (my sons tractor)
1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago
Old 07-12-2013, 11:45 AM
cubs-n-bxrs's Avatar
4 1/2 sounds about right. I had to extent my clutch pedal a couple inches it was a little hard to push.
Old 07-12-2013, 11:49 AM
jmroy's Avatar
jmroy jmroy is offline
I always heard 4 5/8 but I don't think an 1/8th of an inch is really going to matter much. Like cubs-n-bxrs said you'll want a longer clutch arm and depending on what model tractor this is going in it'll start bending where the arm mounts to the dash tower.
Web Developer - Need a website? Contact me.
Old 07-12-2013, 12:43 PM
Yes I forgot to mention that you will have to beef up the area where the throwout arm mounts. It will crack and break in a very short time. Is this going to be a puller? If not taking the red spring up that tight is overkill. I think mid west cub recommends 4 1/2". I set mine at 5" and the clutch does not even slip in 3rd gear. I can chain it to a tree and dump the clutch in 3rd gear and it will dig it's way to china with Carlisle True Powers on it.
Old 07-12-2013, 01:00 PM
jmroy's Avatar
Depends what model tractor, the short tunnel narrow frames are stronger where the clutch arm mounts and don't need to be modified.
Old 07-12-2013, 01:22 PM
austin8214's Avatar
4 1/2" is good.
Old 07-12-2013, 01:41 PM
I have a MWSC Kevlar clutch with the red spring behind my Mag12 that MWSC setup at 5" but I just wanted something good that will last for around the yard. Seems to work just fine no slipping and nice and smooth. That said I don't dump the clutch hooked up to a sled at WOT.
Old 07-12-2013, 01:54 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
The clutch i got from mwsc is the 3puck 1100lbs it came with 2 of the 5/8 split collars an the spring is compressed to 4 1/2 inches. Of course I went overkill for pulling since I only have a k241
Bi-Polar Plowboy Plowboy X Press
Old 07-12-2013, 02:30 PM
It is going in a puller a Cub Cadet 108 and i to have a K241 but its far from stock.Now you guys have me worried about the clutch arm issue where and how would i modify the arm where it mounts.
Old 07-12-2013, 05:18 PM
hey man they told me the samething. i havent had problems yet. knock on wood
