Hello, I am finishing rebuilding a 10 hp engine. bored .010 , however when I went to assemble the oil pan the rod hits the oil pan. I contacted the supplier and it looks as though the rod is a 12hp.? it seems the dipper rod is longer. has anyone had this problem? I did not get any response from the supplier in Ohio, three phone messages and several e-mails, thanks for any help.
How about some pictures of the original connecting rod vs the new one?
Do you have your old dipper? Measure the length and cut off the new dipper as the other one is. I rebuilt a K241 a couple years ago and had to do the same thing.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
The 12HP has a deep pan, and the 10HP is shallow. Yes, a 12HP dipper is longer. I don't see any reason why it can't be cut off like cubs-n-boxers suggested.
shylea 018.jpgI do have the old rod and it is shorter. I only became aware of the deeper pan of 12 hp when I bought my 100 and it had a 12 hp in it, and it went below the frame rails. I thought about cutting the rod , or finding a 12 hp pan. I will try to post a picture . thanks
Did you get your engine balanced? Cutting off the dipper will ruin the balance.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
That is a false statement. Cutting a half inch off the dipper makes no difference. Not enough weight involved to make a problem. Did it on a K241 and noticed nothing at all as far as being out of balance.
I agree with you both. But, cubs-n-bxrs is right.... It's really not enough weight to worry about... UNLESS, your looking for a 4000 RPM, or above, PERFECTLY balanced motor. Even then, the aluminum weight loss is very minimal. It affects a motor more taking the balance weights out of it than cutting the tip of the oil dipper ever would. BTW. Kelly, How much did you have to remove? Only like what 1/2"? Or was it a little more?
That's what I figured.
