Old 12-30-2009, 07:48 AM
dieseldog558's Avatar
dieseldog558 dieseldog558 is offline
Default mule drive
will a mule drive from a 1200 fit a 108 also? are all the mule drives for wide frames the same?
Old 12-30-2009, 09:30 AM
It will fit, but won't work unless you're using the same type of deck on the 108 as you were using on the 1200. The 38/42/48" decks use a mule drive with straight idler pulley arms, and the 44/50" decks use one with angled idler pulley arms.
Old 01-10-2010, 05:52 PM
FFGino FFGino is offline
Default Mule Drive Arms
FFGino here.
MATT! Have you just discovered the straight arms needed for the rototiller mule drives? Everyone else has been talking about twisting the 44/50" arms straight, and you tell us that the 38/42/48" decks already have the straight
arms. Looks like you've been hiding your true genius from us all along? LOL.
Seriously though, that may be a source of the straight arms. I bought mine from an IH/Cub Cadet dealer probably 16-17 years ago to keep the long belt from jumping off. I suspect though that these parts are almost 'hens teeth' by now.
Yes sir, true genius.
Old 01-10-2010, 11:48 PM
You can also pick up a spare 44/50A/C mule drive (whatever size pulleys you need) and straighten the arms. They bend easy enough.
