I can't remember now is there a release lever on a 1211 for the hydro so you can move it without starting it? If not how far would you try and tow it? Thanks!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Take the tunnel cover off. If it does have a release, there will be "buttons" on the top of the relief valves. Push and hold them as you tow it. If there are none, and you tow it slow, maybe a few hundred feet is all I would go.
The 1211 should have automatic release valves.
Thank you,will look sat when I go to get it.
Bring a 1" socket, ratchet wrench, and a 5/16 wrench with you in case it will not move.Remove the cover and loosen the valves and it will roll.
