Old 01-09-2010, 10:28 PM
BajaGTO's Avatar
BajaGTO BajaGTO is offline
Default Headlights from a 1450 - install on a 149
Is this possible with the different electric system? Are the 2 front housings the same?
I want to keep my headlights for blowing snow and stuff.
Any help?
Old 01-09-2010, 11:02 PM
They are not the same. However, I'm pretty sure you can install the 1450 lights in a 149 nosepiece if you leave off the IH emblem. Headlights are headlights, they don't care if you have an S/G or alternator charging system.
BTW, a 149 should have come with headlights standard.
Old 01-10-2010, 09:20 AM
BajaGTO's Avatar
YOu are correct that they should have come with them. But, the one i am looking at appears to have had it's nose piece swapped out with a 109
Old 01-10-2010, 09:46 AM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Does the 149 have the wiring harness intact yet? If not,you will have to make one up. The fusible links for the 1450 are installed in the dash tower as opposed to the 149's is underneath. Not a biggie,but they have different wiring jobs. Make sure you also keep the headlight switch if the 149 doesn't have one,they are about 40 bucks to buy. I am making a spare QL series headlight wiring harness in case I have a failure.Pretty easy to make and the ends that plug into each other can be found on most cars in the junkyard. That 149 looks pretty decent you posted pics of.
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 01-10-2010, 12:18 PM
BajaGTO's Avatar
I won't know if the harness is there, until he drops the machine off at my house. Is there a link on this site where an electrical diagram for the 149 is?
Old 01-10-2010, 12:23 PM
wshytle wshytle is offline
I'm getting ready to do the same thing on my 149. I have a set of lights from a ql and my 149 came with nothing in the nose. I also plan to do the stiffener with a piece of aluminum angle. I understand it helps keep the mesh straight and may help reduce vibrations to the lights. I saw it recently on one of these forums but will have to look it up myself. Maybe if someone knows they can post where this mod is.
Good luck to both of us!
Wayne
Old 01-10-2010, 12:24 PM
bignastyGS's Avatar
http://ccmanuals.info/pdf/86_1650service.pdf
On page 1-10 should help you out for the wiring diagram...
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 01-10-2010, 04:49 PM
I am pretty sure you can swap the whole nose cone from the 149 to the 1450....I did the same with my 1250 and a 12x ....The earlier nose cone has a built in stiffener and it will outlast the quietline design if you have any luck.
Old 01-10-2010, 05:32 PM
Merk Merk is offline
The nose is a direct bolt on:
Old 01-10-2010, 08:58 PM
BajaGTO's Avatar
Excuse my ignorance...but is the nose just the piece with the headlights in it, that the hood attaches to, or is the nose also include the piece from below the headlights (The grille area)?
