does the 1650 - k341 use the same carb as the 1450 - k321?
thanks for any info |
Part numbers for carbs. 47-853-20 = 1450 47-853-29 = 1650
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
For some reason I'm thinking the K321 (14 hp) and K341 (16 hp) engines used a Kohler Carter #30 whereas the K301 (12 hp) and K241 (10 hp) engines used a Kohler Carter #26 carb.
Not sure what the Walboro carb's would be. Take the above info with a grain of salt. Good luck, Bill
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
Pretty sure the carb bodys are pretty well the same it was the jetting that was different.
No more cubs. But never fear there will be more ![]() ![]() ![]()
Part numbers are different, so.... wouldn't that be a not the same carb?
Zippy depends on if the new carbs come with jets or not.my guess is they do and the different numbers tell em which jets to put in. But I could definatly be wrong. Would be willing to see the main differences
There was a pretty big gap in the price of one over the other.
That's just my guess I could be wrong. And more then likely am. I'm sure someone will check out exactly what the difference is.
the k301 an k321 use the same the k341 is a dif part number,like others have said prob the dif is the jets
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
I was told by a carb guy the 30mm on a 321 the bore was smaller than the 30mm on a 341 did I measure one no but this was a puller who rebuilt carbs for guys
