Old 10-24-2013, 08:54 AM
Numbnuts Numbnuts is offline
Default Sleeve hitch differences between 1650 and 782?
Hello folks,
Does anyone know if the sleeve hitch for the wide-frame 1450/1650 will fit the 82 series, or what the differences in the parts might be?
Thanks.
Old 10-24-2013, 09:56 AM
JLM78 JLM78 is offline
Originally Posted by Numbnuts View Post
Hello folks,
Thanks.
the lift bar that runs for the hitch to the trator lift is not the same.
Old 10-24-2013, 11:19 AM
The lift bar for the 1650 has a curve, while the lift bar for the 782 is straight.
Old 10-24-2013, 01:40 PM
Default Re: Sleeve hitch differences between 1650 and 782?
Appreciate the info, thanks! I'm looking at a wide-frame hitch set for sale. Looks like for what just the bar costs ($45+), I may cut and weld it to fit my 782.
Old 10-24-2013, 02:32 PM
red56turbo's Avatar
Also, the early quietlines had the bar going through the actual cast part to allow it to pivot. On the later quietlines and the 82 series, it used Frankenstein bolts. You could always add bushings to the 782 frame and use the bar if it's an early one.
Josh
Diesel Cub Cadets...........
Old 10-24-2013, 05:23 PM
Josh, I think this is like the one I'm looking at:
http://www.partstree.com/parts/?lc=c...&dn=0028100032
Thanks.
Old 10-24-2013, 07:13 PM
Thanks.
If you need frankenstein bolts, I make them
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 10-24-2013, 07:30 PM
The upper casting is the same for all WF. The difference lies in the rear of the Frame. Early frames had a collar spot welded to the frame and used a pivot rod. Later frames did not have those collars and simply had a hole in the frame for the so called Frankenstein Bolts. See image of frame with collars.
Old 10-24-2013, 08:31 PM
OK, Roland I don't see the collar so I think I will need Jeff's frankenstein bolts!! Just in time for Halloween.
Bret
Old 10-24-2013, 10:16 PM
If you guys are talking about a Three Point Hitch... Please stop saying "sleeve hitch"
http://www.onlycubcadets.net/forum/showthread.php?t=4
