Old 11-05-2013, 03:01 PM
johncub7172's Avatar
Arrow Repower IH Cub Cadet 72 with Kohler K241
Here is the motor. Today I prepared it to turn white tomorrow. After this and that, I cleaned the block with cloth rag and pure toluene. Tape where the starter generator will mount, you have good ground this way. I have plenty of gasket material, and the cam cover was not cleaning up as good, so removed, have the other parts ready!
Here is a before picture of the Kohler K241:
We're Going On!
Old 11-05-2013, 04:27 PM
OldAndInTheWay's Avatar
Really nice!
Be nice to do one to be a sculpture on the mantel.
Old 11-05-2013, 04:31 PM
cubfixer's Avatar
cubfixer cubfixer is offline
That is one CLEAN engine!
John
Old 11-05-2013, 05:55 PM
Engine looks great John!
Old 11-05-2013, 10:41 PM
Engine looks sharp, John!
Old 11-05-2013, 11:03 PM
cnixon's Avatar
cnixon cnixon is offline
That's Pretty....
Old 11-06-2013, 12:04 AM
Thumbs up
Well, all I'm hoping for is to have a clean part for the paint to stick to. She's clean,....last time we'll see it so!
p.s I'm almost sure everything else engine related is completed in CC Yellow!
Old 11-06-2013, 12:11 PM
Thumbs up
I made the first coat today. The old Kohler sucked up a lot of paint. I plan on Friday tipping the 241 over to get at the belly pan,
then I might as well run out the rest of the sealer on the engine. Sure is not pretty, but I have some other special primer for it which will roll out the red carpet for the yellow.
Old 11-06-2013, 01:46 PM
Thanks for the update, John.
Old 11-11-2013, 05:28 PM
Default enjoying the ride!
Been busy, but not much to report. However, I'm happy with the way preparing and sealing work has gone thus far. I have now begun to take inventory of all engine related components, hunt them down, check off what I have prepared and what I need to. A lot of work is still needed to begin assembly of the Kohler K241, and I'm not sure when I will get to the yellow! But anyways, here is a up date thus far!
Beginning the first coat
Moving along, up to the second coat
Governor control arm, points cover, cam cover and hardware
Had to make a new cam cover gasket since I have all kinds of gasket material
No need to hammer out gaskets. All I needed to do was apply pressure to the die and turn clock wise and the hole was cut right out! Here is another look at improvise at its finest,
