Old 11-11-2013, 01:54 PM
Default Grease Zerk
I noticed that one of the grease zerks is missing on the front axle of my 782. I've never had a cub with them missing before. How do they go in, and where do you buy them? Would Tractor Supply have them? Thanks guys!
Old 11-11-2013, 01:57 PM
OldAndInTheWay's Avatar
Just screws in.
Old 11-11-2013, 02:38 PM
Also, what's the correct size for them? Sorry for the question, but with my sight, they are hard for me to see.
Old 11-11-2013, 03:11 PM
Shaner Shaner is offline
If its missing... it could be broken off...you will need to easy out the old one and re-thread the hole and the new zerk will thread in easy
Old 11-11-2013, 04:31 PM
I think they are 3/16 Allen and it's been awhile since I messed with one but I think they are press in too.
Old 11-11-2013, 06:06 PM
This from the Cub parts site. Grease Fitting, 3/16 Part Number: 737-3000
Old 11-11-2013, 06:14 PM
Yes they are a press fit.
Remove the spindle and knock the remaining piece thru.Then put the new one on.
Old 11-11-2013, 06:30 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Any good hardware store or farm supply should have some
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 11-11-2013, 08:16 PM
MinnesotaCadet's Avatar
One place I remember seeing zerk fittings was at a place here in Northern Minnesota, I just happened to stumble upon them. It was a fleet supply place and they actually had this outside along with a lot of other newer Cubs and different brands. You can probably find them at a fleet supply place if you have any North Carolina.
Old 11-11-2013, 08:27 PM
kostendorf's Avatar
I'm glad this topic came up, because I have an axle that was missing a grease zerk on the right side. It did not have one. I had to drill a hole thru tap and install one.
