Old 12-21-2013, 04:31 PM
Giotundo Giotundo is offline
Default First post white smoke
I recently acquired a cc 125 and have addressed a few problems it had and had it running great. Today I washed it off with the pressure washer and let I sit for 20 min or so idling before I parked it. I then parked it and shut it off then had to move it again after starting it a huge cloud of white smoke came out from under it and it sputtered and died. I checked the oil for gas, changed it, checked the air filter then tried to restart it. Nothing. I tried spraying quick start in the carb and still couldn't get it. It turns over fine it seems like it's not getting a spark though. Any help or ideas would be appreciated.
Old 12-21-2013, 04:35 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Pressure washers do that. You have a wet coil inside the spark plug wire connection OR wet points. I suspect both. Take the points cover off and you wlll see condensation from the pressure washer. Take the spark plug wore off the coil, look inside , and you will probably see moisture. Take WD-40 and spray both AFTER taking a rag to the moisture. Mop up the remaining WD-40, and you should be good to go.
John
Old 12-21-2013, 04:37 PM
Yep, BTDT, more than likely the points are wet.
Old 12-21-2013, 05:00 PM
Just to mention another option to the great advice that others have already provided....You may also want to dry off and sand the frame and wire connection of your ground wire to make sure that you have a really good ground connection.
Old 12-21-2013, 06:24 PM
Welcome to OCC!
Old 12-21-2013, 06:59 PM
Thank you for all the answers. As I'm very new to this could someone explain or maybe have a picture of where to access the points I can't find any google results.
Old 12-21-2013, 07:41 PM
Ok found the points cleaned them off and replaced spark plug and still no spark.
Old 12-21-2013, 07:47 PM
125 service manual
http://www.onlycubcadets.net/forum/s...ead.php?t=4642
Kohler KT engine service manual
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Download the PDF files at these two links. Will help you alot.
Old 12-21-2013, 09:12 PM
Merk Merk is offline
I have had this problem with my 149.
I dried the points and it ran.
Check your point cover to make sure there is a gasket between the points cover and a groment on the wire going to the points.
Project Uncle Dick
Cub Cadet 70
Old 12-21-2013, 09:25 PM
gmbadgley gmbadgley is offline
Easiest way to check is in the dark, Look for spark jumping to ground around the coil, spark plug wire and spark plug. It will show up real well in the dark.
"If I can't fix it, I can screw it up so bad no one else can either"
