Go Back   Only Cub Cadets > Resources > Technical Library - Tractors
Closed Thread
Old 02-02-2010, 05:59 PM
Admin's Avatar
Admin Admin is offline
Admin
Default Analog Hour Meter
Part No: IH-107201-C8
These hour meters were seen on the 169, the Quietline Series, and early models of the 82 Series.
The International Cub Cadet Tractors are equipped with an hour meter which is located on the instrumental panel. It indcates the actual hours of engine operation, enabling the operator to determine without guesswork, when lubrication, change of oil, or periodic inspections are necessay. It also provides a means of computing cost of specific jobs. The hour meter operates whenever the engine is running or the ignition key is in the “ON” position.
The Red dial indicates the number of hours from 0 to 60.
The Yellow dial indicates the total hours of operation up to 600. For one revolution of the red dial, the yellow dial moves 1/10 of a revolution.
The White dial indicates that the hour meter is operating
Closed Thread
