Old 01-24-2014, 03:09 PM
ihsteve ihsteve is offline
Default Cub Cadet 123 hard starting
i have a cub cadet 123. it turns over like it has a dead battery i picked up new one and still same thing what can it be? i changed starter gen an still same thing. could it be a bad selanoid? hany help would be gratly appreciated
Old 01-24-2014, 03:20 PM
Bad battery cables. Bad connection.
Changed the S/G with a new one? Or just another one?
Old 01-24-2014, 03:38 PM
How cold is the tractor? You may need to warm it up.
Old 01-24-2014, 03:42 PM
Several possibilities, as others have already mentioned some good advice, I would just add that you could check your ground connection(s) to make sure they are clean, as well.
Old 01-24-2014, 06:08 PM
its in a heated garage. i just changed a ground wire and cleaned both ends. im at a loss
Old 01-24-2014, 06:17 PM
ok i pulled the air cleaner off if i choke it out with my hand it turns over like it should and fires right up. if i take my hand off it turns over like it has a dead battery.
Old 01-24-2014, 06:26 PM
Calvins66Cub's Avatar
Mr Miyagi hands!
Check this thread out:
http://www.onlycubcadets.net/forum/s...ad.php?t=29600
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 01-24-2014, 07:17 PM
Sounds like the timing is off, and the carb is lean.
Old 01-24-2014, 07:34 PM
Did you use just choke without the hand over it?
sounds like a timing issue.when was this last run?
Up to 534 and counting...
Old 01-24-2014, 07:50 PM
johncub7172's Avatar
That's interesting,...... . Why use your hand and not the choke control cable? Looking in the Operator's Manual 1 084 564 R2 71, 102, 122, and 123 Tractors, looks like a fuel and carb adjustment. Is the vent hole in the gas cap clear and clean?,... because under that plastic insert you might find years worth of trash. Possible causes are choked improperly, flooded engine, defective ignition or loose wiring. Don't really list remedy for your specific starting procedures.
I think the group can help you figure this out, good luck!
