Old 02-07-2014, 11:40 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default QA backhoe
as some of you may know, i have a 1772 with a KW loader and backhoe. i was thinking it would be nice if i could take this backhoe off when im not using it without spending 2 hours unbolting 8 fasteners, disconnecting 4 hoses and then blocking it all up. i came up with this quick attach mounting set up. i like how the Kubota QA worked, so i took some ideas from that. i actually had 80% of the materials on hand, so that helped out the wallet. the only parts i had to buy were the hydraulic quick connects and 2 clevis mounts. the bottom of the mount sits in 2 "J" hooks and the top mounts with 2 3/4" pins. it was a bit tricky to get everything lined up so the pins would just slide right in without a hammer. lots of tack welding, testing, and grinding. took me the whole month of January but finally i got it. here's a few pix of the fab work and a video demo of the QA setup.
https://www.youtube.com/watch?v=sgkY-qiXfxQ
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-07-2014, 12:05 PM
Cool set up
Old 02-07-2014, 12:26 PM
Sweet setup and real good shots of your work on your video!! You've done some really smart fabrication there.
Old 02-07-2014, 12:38 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
cool idea only thing I change is I make tapered pins to make lineup alittle easier
Old 02-07-2014, 12:40 PM
Top notch work, and great vid, Ken!
Old 02-07-2014, 12:47 PM
Very cool setup!
Old 02-07-2014, 12:48 PM
ken6x6's Avatar
thanks!
yes, tapered pins would help. i might just take the pins i had and put them on the lathe and taper the ends down. good idea! thanks.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-07-2014, 12:56 PM
Muzzy Muzzy is offline
Slick!! That makes things alot easier. Nice work.
Old 02-07-2014, 07:19 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Looks good!! Need a few vids of that thing doin work!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 02-07-2014, 09:00 PM
ken6x6's Avatar
i can make a video of it working. might have to wait till all this snow is gone so i can find the dirt again.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
