Got the sickle mower mounted. Was trying to use the deck lift to raise it, but it is very slow and weak
The other two remotes work fine. It does not bleed down when the tractor is off. Is it in the valve or maybe the cylinder?image.jpg |
Problem is in the valve. I switched lines with the valve for blade angle and the lift works fine. But now the blade only angles one way.
Sounds like it's blowing by, fluid going to tank instead of going through the port, or the spool isn't being fully shifted. Check the handle and linkage.
