Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 03-31-2014, 12:34 PM
782CC 782CC is offline
Default Electric clutch for CH20 ?
I purchased a CH20 for a replacement engine some time back. It has the double pulley and tensioner system instead of a electric clutch. Will I need somthing like this to fit it up to my 782 or 2072?
CL listing in case that did not work.
http://kansascity.craigslist.org/grd/4400586822.html
Old 03-31-2014, 12:39 PM
Leadslingingdaddy's Avatar
Yes...I believe the models you referenced had a 4 1/2 electric PTO pulley. those look to be 6 inch...
Old 03-31-2014, 02:31 PM
I was not clear enough, here is a pic of what I am concerned with. It certainly wont run my current 782 implements. So I guess my real question is if the CL posted clutch might be an electric clutch to fit my CH20. Pulley size is no concern, actuallyl a plus to go 6 inch. I will change ratios as needed. I may not know until I pull this PTO apart...
Old 04-04-2014, 04:26 PM
So I decided to pick up both he had. Figure one might be of use elsewhere. Starting to concern about this CH20 as a donor engine. Might be best to find a appropriate M18 for when the KT17 dies. Think I did figure out the donor in my pic must be
a 3206. The PTO is called an E-VAC. I did not know that. Or that it came with diff lock.
