Old 04-23-2014, 10:16 PM
OffTime's Avatar
OffTime OffTime is offline
Question WF Mule drive pulleys
I have a 129 that I am fixing up to be a general yard machine and garden worker. I just purchased a tiller for it and am wanting to rebuild the mule drive. I would like to replace the stamped steel pulleys with solid steel pulleys. Would anyone have any leads as to where I can get the solid pulleys? Part numbers?? NAPA, O'Reiley's, Oregon, Stens, Rotary, JD, etc, etc. Any input appreciated. Thank you.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 04-23-2014, 11:26 PM
Bob95065 Bob95065 is offline
+1 I need them too.
Old 04-24-2014, 07:43 AM
sawdustdad's Avatar
Mule drive pulleys are available at both these sponsors though they don't look like solid steel. Someone else will surely come along with a solid steel version...
http://ccspecialties.org/implementparts_2.html
http://ihccw.com/mowerparts.html
Old 04-24-2014, 07:44 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
check out Sugarmaker's threads on his 129 refresh of tiller and mule drive.
http://www.onlycubcadets.net/forum/s...640#post255640
Old 04-24-2014, 09:16 AM
These are nos, they are the correct pulleys for the tiller mule drive, IH 493164 R91.
Up to 534 and counting...
Old 04-24-2014, 10:06 AM
Are they for sale?
Old 04-24-2014, 10:33 AM
I might have one used one,I called one place and it is $70 each wow.The good thing with these you remove the snap ring and replace the bearing when it wears out.
I am sure that mc master carr has something like it.let me know if you need measurements.
Old 04-24-2014, 10:41 AM
Not sure but I may have a couple in need of bearings, gotta dig through my stash of stuff that looked like it was to good to trash that I have no use for but I better save it cause I may need it someday. One of the reason our shops are too small.
I will report back with my findings.
Old 04-24-2014, 01:43 PM
I am looking for a pair too. Anyone know a source?
Old 04-24-2014, 03:23 PM
danfeste danfeste is offline
I just rebuilt a pair of solid pulleys. The bearings were $3.57 each from usabearingsandbelts.com the part number is 6300-2RS. They are a metric bearing sealed on both sides, size 10x35x11mm. The brand of them is RB Tech, and the quality rating was better than a SKF bearing which was $30+. I have tilled with them a few hours so far and they seem to be working good. So if you can find a set with bad bearings you can go this route.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Tags
mule drive, pulley, tiller
