I have a 62 original and the timed mower deck belt broke today while I was mowing....I am going to order one tonight. I was looking at the deck and I didn't see any way to take the spindles loose to slide them in to put the belt on. Also does anyone know the best place to order the belt from I know the part number is IH 464860 R2. Thanks for any and all help
Thank you J-Mech I really appreciate your help. I'm sure I'll have the ole girl back mowing before the yard will need it.
Ok...got her back together and mowing. What I learned was that the timed belt was way to tight causeing it to bind which eventually broke the belt. I first read the manual...thanks to J-Mech and then tore the deck apart. Regreased the bearings, reset the belt tension so that it was tight but everything still turned freely. I replaced both belts because the small belt that engauges the deck was badly stretched. After I checked everything and sharpened the blades I took her for a spin....mowes beautifully just like it was designed to do. Thanks again for all the help.
