Old 08-05-2014, 12:16 PM
bolivier's Avatar
bolivier bolivier is offline
Default A little box blade modification
I got this blade a while back with a tractor. The tractor had a tiller gearbox, and the box blade was set up to hook to that. Well....I have one tractor with a gearbox on it, and it is not the tractor I want to use the box blade with. I had part of a snowblade subframe that someone had cut up at some point. So, I decided to make the box blade work with any of my tractors that have the rear lift. I set it up similar to how the cub cadet #40 box blade attaches, except I made it use lift straps instead of a fixed mounting to the lift like the #40. Works good. It was free. The subframe was perfect. Now I can use it on any tractor I want. Just need some rippers for this thing now.
First 2 pics are how it was when I got it.
How it is now.
