Old 09-04-2014, 10:55 AM
rwairforce rwairforce is offline
Default k301 12hp in a 127
I have a 127 which has the voltage reg sitting directly above the muffler. A buddy pointed out that I don't have a shield to help reduce the heat on the regulator. Does anybody have a picture showing what engine tin should be on a 12hp.
Is that piece called the muffler heat shield? If you think I should have one I'll try listing in the "items wanted" section.
Thanks
I attached the best photo I could find with the shield in question. I wish my engine looked like this one.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 09-04-2014, 12:32 PM
Yes, you should have one.
It serves several functions:
Muffler brace
Heat deflector/shield over the muffler
It also directs the air coming off the motor over the muffler and out the front
Want ad, sponsors above are good options.
Old 09-04-2014, 02:25 PM
Thanks Jonathan.
Those are probably the exact reasons they used one when they built it.
I think I'll look for the remainder of the tin as well. I don't recall seeing the piece covering the head either.
Randy
John Deere 140 H3
Sears: GTV16
Old 09-04-2014, 02:41 PM
cub_junkie's Avatar
cub_junkie cub_junkie is offline
Randy.
I may have an extra heat shield out in my shed if you have not found one yet i could look
Travis
Cub Cadet 70x2, 86,123,1450
attachments include:
brinly planter,
cultivator,
10" plow,
potato plow,
WF and NF IH blade, IH QA42A snow thrower,
IH #2 tiller, IH rear blade,#2 IH cart
Old 09-04-2014, 02:49 PM
Thanks Travis.
PM me with what you find. I may need the piece for the head as well. Thanks for looking.
If you find them, could you paint them Cub Yellow for the 127 I have? Forget that request....
Randy
John Deere 140 H3
Sears: GTV16
Old 09-04-2014, 04:43 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
When you find that muffler holding/heat deflector.......
You might want to weld a nice beefy flat washer over the head bolt hole nearest the carb (I think).
Then paint up pretty.
Have had most all of the ones I ever had crack and separate at that head bolt location. The shield. that is.
Old 09-04-2014, 07:00 PM
Don't forget about the spacer between the muffler and the shield. Also, aren't there spacers between the head and it also?
Old 09-04-2014, 07:06 PM
There are different heat shields for different spark plug locations.
Up to 534 and counting...
Old 09-04-2014, 09:56 PM
I guess I never considered that Lew. I have seen some flat ones and some "eardrop" angled ones. So is that the reason those were different on the 12 hp Kohlers because I have seen both on the 123's and always assumed that they were parts that were handy when finishing up a production line.
Old 09-04-2014, 10:19 PM
The dog eared ones were only meant to fit on a 102,122,123 when they were produced,there is a clearance issue with the grill housing,but they work on the later models.I have a 123 with a replacement 12 in it and they bent the newer shield to get the motor in.
