Old 09-04-2014, 01:43 PM
imnotacollector imnotacollector is offline
Default The 582 restoration has officially began!
I finally had enough time and space in my garage to start the tear down. I plan to start ordering parts in the next week or two the plan is to replace all seals, bearings, gaskets and any other wear items. If the engine is in good shape, it will get rebuilt, otherwise look to repower. Jmech, do you do rebuilds on the Briggs? Also any tips or suggestions on things to pay extra attention to would be greatly appreciated.
Old 09-04-2014, 02:26 PM
jimbob200521's Avatar
Looks like a good start!
And btw, I'll bet that J-mech will do it, but that he will also advocate swapping out the Brigg's-a-crappin for Kohler
-Ryan
Old 09-04-2014, 02:31 PM
I have one tore down too. No, I won't rebuild a B&S. Like we talked the other day, if the motor is bad, your better off with an M or a CH. The motor I pulled out of mine is bad. I have no intentions of fixing it..... even for myself (no labor, LOL).
Fixed your pic too. It was hurting my neck.
Old 09-04-2014, 02:36 PM
Thanks for fixing the pic. Silly iphone. If I have to repower I will probably go with the ch. Thanks for the input gentlemen. I'll keep updating as she progresses.
Old 09-04-2014, 02:59 PM
yeeter yeeter is offline
It will look dramatically different when you are done!
When you say replace all seals, gaskets, bearings - do you have a list? Im curious as I am contemplating similar decisions. In particular, do you include:
front wheel bearings?
hydro to rear end gasket?
trunion gasket?
rear end bearings? (Im not sure whats in there... more than one I think but I wouldnt think they all need it)
lift cylinder rebuild?
the bushings for the brake lever, etc, where they go through the frame? (maybe put zerk fittings on these?) Most people dont take these apart for painting.
hydro release valves?
adding zerk fittings anywhere else?
rear end cover, back cover gaskets?
rear axle seals/bearings?
rag joints?
what did I miss?
Im just asking because I am doing some, but not all of these on mine and would love to hear others recommendations on which are worth it and which are better left alone until a problem.
(ok, it just hit me that yours is not a hydro, and manual lift so not all these apply. But some do...?)
Old 09-04-2014, 03:18 PM
I wouldn't replace every bearing. No need. If you have it apart, look them over. If the rear end has had water in it, look them over. Otherwise, they don't very seldom fail.
Old 09-04-2014, 03:59 PM
I agree with this. If the bearings roll nice and don't have pits in them then there's no need to replace them unless you have extra money to blow.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-04-2014, 05:17 PM
Ok, thanks for saving me $. I just thought while I was in there, but if they don't go out very often I'm ok with just inspecting bearings first. Thanks everyone.
Old 09-04-2014, 09:13 PM
So tearing into engine resulted in mice losing a home, and discovering that both cylinder walls have grooves in them tat could be felt through the rag used to wipe them down. Looks like a ch repower is in this cubs future. Thanks again.
Old 03-07-2015, 07:11 PM
It's been awhile since I was able to do much with the 582, but today I was able to pick up a low hour Briggs opposed 18 on the cheap. I'll have to borrow parts from the sixteen to make it right. Mainly being the muffler which is different and the shroud that goes around the muffler. Easy peasy swap,then just bolt everything in. Right now everything is put back together, except engine of course, I plan to run it this spring for tilling, and then get her sanded down and ready for paint.
