Old 09-25-2014, 02:14 PM
OldCubby OldCubby is offline
Default Replacement idle screw spring
So, a few months ago I rebuilt the carb and engine in my 1250. Works like a charm...but the idle screw spring was all rusted and I reused it, but I really need a new one. Because its causing idle problems for me. So, after doing some research. I have found that its difficult to get a replacement spring. What have others found to work for them? Thanks
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 09-25-2014, 03:16 PM
What is the Kohler Model and Spec number to your engine...???
Old 09-25-2014, 03:21 PM
Model: k301aqs
Spec: 47622d
Old 09-25-2014, 03:37 PM
Per the Kohler Manual for Adjustable Carb 47-853-20:
200380-S Spring, idle needle
232555-S Spring, idle screw
Both available from either your local CC or Kohler Dealer(s).
Old 09-25-2014, 03:45 PM
I found those part numbers. But when I looked online at Partstree.com and cubcadetpartsnmore.com they said to call them, which was what pretty much every other site is saying as well. I'll give the local cub cadet dealer a shot.
Old 09-26-2014, 12:31 AM
http://www.kohler-engine-parts.opeen.../spring-200380
http://www.amazon.com/Kohler-Part-20.../dp/B00CNX4DLO
http://www.kohlerenginesparts.com/Pa...OH//200380-S/1
Here's at least three places you can get it......
Old 09-26-2014, 06:21 AM
This is why it is better to rely on the accuracy of information from Cub Cadet or Kohler rather than some supplier.
Old 09-26-2014, 07:03 AM
Well said, and nice find Jonathan! Thanks fellas!
Old 10-02-2014, 08:07 AM
ok, so I got the new idle spring. While I was at it. I ordered a new brass governor shaft nut. I got the old one off and put the new one on. Now, my governor is all out of wack. Here's the issue....when I took it apart....i'm not sure I put the tab back on the governor correctly. If I take the nut back off and use a flash light I can see that I can orient the tab horizontally or vertically. Now, I don't remember how it was when I reassembled the engine...but I did could see up through the oil pan to ensure I assembled it correctly. I can't do that this time. So, if I were to look inside the hole, how should I see that tab? Horizontal or vertical?
Old 10-02-2014, 08:22 AM
Did you follow the procedure in the Service Manual (TP-2379) as outlined on pages 12.1 - 12.2..???
