Old 12-18-2014, 08:51 PM
donald EDWARDS donald EDWARDS is offline
Default Engine swap
Does anyone out there know if a k321 14 hp will fit on a cc 126 or 108?
Old 12-18-2014, 09:11 PM
It is a direct swap on a 108,with mods to the frame it will fit in a 126,but i would try to avoid doing that to the 126.
Up to 534 and counting...
Old 12-18-2014, 09:17 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Welcome,Mr. Donald...
A 14 hp will not "fit" on a 126 without modifications. The flywheel on a 14 hp is larger than the original 12 hp and will not fit between the frame rails.
A 14 will "fit" on 108. The 14 hp in question,, does it have a starter/generator or a gear starter ? If it is a gear starter, a few changes might be in order, mostly concerning wiring and the pto clutch.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 12-18-2014, 09:19 PM
Or you could put the small flywheel and housing on the 14 and it will fit......
Old 12-18-2014, 09:30 PM
sawdustdad's Avatar
Great idea, Jonathan!
Old 12-18-2014, 09:36 PM
Welcome to OCC!!
My first Cub Cadet was a 108 with a K321, it had been swapped before I got it in 1980,,,,,,
The tractor had mowed 8 acres for over a decade, then was replaced by a 1872 CC.
Some if it is still in the weeds, somewhere!!
Old 12-18-2014, 10:46 PM
Ya gotta use the small bearing plate too.
Old 12-18-2014, 11:35 PM
Yes. Yes you do.
Old 12-22-2014, 04:44 PM
garnold's Avatar
garnold garnold is offline
I was thinking about this and wanted to ask a completely noob question. From what (little) I know at this point the weight of the flywheel helps with the torque of the engine correct? The weight of the flywheel spinning helps move the piston inside and then the explosion in the head continues the process over and over. If you put a flywheel from a 12 on a 14 are you actually making the engine less strong? So are you kind of ending up with a 13hp engine (no math being used here just trying to use a point)? What is the end result (besides the engine fitting in this frame) when it comes to power after doing this? If the poster can fit a 12 in and the 14 with a smaller flywheel equals less power (again still not sure if this is even the case so asking) is it even worth it? This is more for a learning thing for me. The poster asked if he could fit a 14 into his frame and you folks offered him a way to do this so that all makes sense to me. Just looking to learn what actually happens to the engine after this change has been made.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 12-22-2014, 04:55 PM
Just for the sake of argument...
If you put a 14 HP flywheel on a 7 hp engine, do you get 10.5 HP?
