Go Back   Only Cub Cadets > Resources > Cub Cadet Parts Sources > Parts Cross Reference
Old 12-21-2014, 03:20 PM
darryljs's Avatar
darryljs darryljs is offline
Default Cross Reference Cub Cadet to NAPA
Here's a list of some stuff I found from NAPA. I think there may be more things. Hope you find this useful.
Tie rod end CCC # 723-3018 NAPA # 7-04231
3/4" wheel bearing IH # 394883R93, NAPA # 7-04292
1" wheel bearing CCC # 741-3002, NAPA # 7-08412
Electronic Voltage Regulator plug NAPA # 7-016008
5 prong ignition switch plug NAPA # 7-016034
Breaker points Kohler # 47-150-03, NAPA # 7-01029
Condenser IH # 62188C1, Kohler # 230722-S, NAPA # 7-01338
Muffler, models 102-149 IH # 393840R91, NAPA # 7-03680
Hydro filter CCC # 723-3014, NAPA # 1084
Hydro filter for auto gear pump CCC # 723-3014, NAPA # 1410
Rear wheel seal CCC # 721-0187, NAPA # 9878
Hydro input seal IH # 394847R91, Sundstrand # 9008000-6201 NAPA # 6204
Hydro trunion seal SN 592014 & below IH # 383534R91 NAPA # 6720
Hydro trunion seal SN 592015 & above Sundstrand # 9008000-6701 NAPA # 6763
PTO bearing, models 70-169 IH # 60071C91 NAPA # RA100RR and PRA100RR (cheaper version)
Engine oil filter Kohler 52-050-02-S, NAPA # 1348
Engine oil filter Kohler 12-050-01-S, NAPA # 1056
Shaft seal for Narrow Frame Hydraulic lift pump IH # 347478R91, NAPA # 4911
Sway bar repair kit to replace Quiet Line ISO mount rubbers NAPA # 265-1285
Spark Plug Cross Reference Chart
Engine – Kohler K241 (10 HP), K301 (12 HP), K321 (14 HP), K341 (16 HP)
Manufacturer and Number ------- Mfgr. Stock Number
Champion H10C --------------------- 844
Denso W14L --------- -------------- 6013
NGK B4L ---------------------------- 3112
14mm, 7/16 reach, 13/16 hex. These plugs recommended for stock engines.
Engine* – Kohler K241 (10 HP), K301 (12 HP), K321 (14 HP), K341 (16 HP)
Champion H8C ------------------------ 587
*These are colder heat range plugs for use in modified engines with higher than stock compression ratios.
Engine – Kohler K141 (6.25 HP), K161 (7 HP), K181 (8 HP)
Champion J8C ------------------------- 841
14mm, 3/8 reach, 13/16 hex.
Engine – Kohler KT17 Opposed Twin
Champion RV17YC --------------------- 25
14mm, .460 reach, 5/8 hex.
Engine – Onan 20 HP Opposed Twin
Champion RC14YC --------------------- 431
14mm, 3/4 reach, 5/8 hex.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 09-17-2017, 12:47 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Default Cyclops axle seal
Cyclops wheel seal CCC # 921-3020A National # 474256 SKF # 11930
Source: Oaks thread.
http://onlycubcadets.net/forum/showthread.php?t=35077
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
