Ok guy's, long time lurker first time poster. I have to say the knowledge in these pages is priceless and has saved me a lot of long hours and bloody knuckles! So to my question. I have access to a Lakota cheater cam and a Zack Kerber gov 3 cam. Any one here running these cams? This is going in a .030 over k301 with a 6.125 rod and the short piston. I'm leaning towards the Kerber but would like to know if it will be to much cam for a 3800 rpm motor. The class I'm running is basically a stock class with no cam restrictions and a 4000 rpm rule. I'm also wondering about a weighted front starter pulley, are the benefits there in the slower turning engines? Also while I have everyone's attention, opinions on the life expectancy of a forged crank with a heavy flywheel and starter pulley under 4000 rpm, or do I need to spend the extra money on billet? Thanks for any help that you guys can offer!
the #3 cam from Kerber is designed for a goverened engine. I used one last year in a customer engine and was very pleased with the numbers. very wide band. you do need to use thewide base lifters
forged crank ? I see no problems, stock cast crank I would. stockers like swinging mass |
Thanks for the reply! Kerber it is, I have springs and lifters so now I'm waiting on the crank. Hoping to pick up a bit more torque and the old girl to pull! Took first in it's only pull last year but I think it was more dumb luck than anything, anyways I want to put her several feet further down the track this year!
Second vote for the Kerber gov #3 cam. I have two of them you will not be disappointed.
Does the #3 cam from Kerber have a smooth idle?
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Fall 2014: http://youtu.be/mkDnRouJx5E
This one has a gov #3 in it with LP head all other internal parts are stock dimensions. I don't think it idles to bad. It just likes it better up about 1,200 rpm. |
? who worries about idle? its all about WOT
The only reason I'm concerned with idle is to sneak into a bone stock class!
You are not going to be able to sneak back into a bone stock class with that cam. You will put 50+ feet on second place.
