Old 02-17-2015, 10:29 PM
rbarri2's Avatar
rbarri2 rbarri2 is offline
Default How tight for deck spindle grease screws
I'm cleaning up a mower deck on a 3 spindle deck for a model 70 and I'd like to know how tight the grease fitting screws for the spindles needs to be.
The torque of the grease screw affects how smooth the spindle turns, but I don't want it to be too loose and fall out.
I reviewed a copy of the IH Rotary Mower manual, but could not find info on this.
I also searched on this forum.
thank you.
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE.
1968 Cub Cadet 124 with deck and #2 Trailer
1965 IH Scout 80 Champagne Edition
1968 IH Travelall 4x4 and factory PTO winch
1955 IH Refrigerator
Old 02-18-2015, 08:13 AM
Just put 'em in snug, I'd be more concerned with them breaking off if attempting to get 'em real tight, & Ya don't want to do that. They are spring loaded to keep the grease in. If it spurts out of the fitting after you remove the GG, the spring check ball is damaged and you should replace the fitting. Examine te end of the fitting. It don't take much of a bump w/something hard to screw 'em up.
The torque on the fitting has nothing to do with the grease flow in the bearing.
It's the spring loaded ball that keeps it in. 2 or 3 strokes at regular intervals should be sufficient unless the seals (which keep the grease in the other end)are blown out in which case the grease will
practically run through and out of the bearing and won't hang around very long while in use.
Old 02-18-2015, 09:05 AM
rbarri2's Avatar
I will try to get some pictures later today. I wouldn't try to tighten up too much because the spindle just wouldn't turn at that point.
I don't remember any springs in mine.
Also, if I'm understanding correctly, the grease seal needs to be seated into the deck correct?
Old 02-18-2015, 09:14 AM
Post a pic of what your working on. Something sounds wrong like maybe you didn't put the spacer in between the bearings. They shouldn't bind up when you tighten them up.
Old 02-18-2015, 09:29 AM
Sam is correct, there should be a spacer between the bearing's to prevent over tightening. Id be willing to bet there's a spacer missing or its assembled incorrectly.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-18-2015, 09:55 AM
rbarri2's Avatar
It's a new to me mower, so who knows what the previous owner did.
I just took it apart to inspect, clean, and lube. I kept the parts in order as I did it.
Here are some pics. I'll get more detailed pics if needed.
thanks guys!
Old 02-18-2015, 10:02 AM
Well here is how it should go together. The spacer we are talking about is in red in this pic. Pretty sure the service manual for it is in the library. If not send me a PM with your e-mail address and I'll send it to you.
Old 02-18-2015, 10:20 AM
rbarri2's Avatar
thanks, I'll take a look at it again and make sure I'm not missing anything.
Old 02-18-2015, 02:56 PM
rbarri2's Avatar
I found the culprit.
I am missing the washer that goes between the pulley and the grease seal.
I took the other side apart and found the washer and compared the good side to the diagram. The good side spins smooth and is tightened properly.
So, where can I find a washer?
I'll start calling the sponsors above.
thanks again, everyone!
Old 02-18-2015, 03:00 PM
rbarri2's Avatar
My helpers.
