Old 03-16-2015, 03:18 AM
gdheck's Avatar
gdheck gdheck is offline
Default Going price of Brinly cat. 0 plow?
What is the going price of Brinly cat. 0 plows now? I found one for $300, but that's way too high in my opinion. I'm not too interested in using a sleeve hitch plow and adapter. I would rather just get the whole Brinly cat. 0 setup.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 03-16-2015, 07:00 AM
Merk Merk is offline
They going for $275 to $300 in my area.
Project Uncle Dick
Cub Cadet 70
Old 03-16-2015, 02:23 PM
red56turbo's Avatar
Yep,
That's to going rate in my area, too. $250-$300. Be sure to scour CL and even watch the green Jane Doe sites. Sometimes you can find one for less and if you do, don't hesitate. If priced good they sell fast. Took me awhile to find mine. Good luck.
Josh
Diesel Cub Cadets...........
Old 03-16-2015, 02:58 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
That's the going rate. Would I pay that, NO.
I lost track of what I own a long time ago!
Old 03-16-2015, 03:18 PM
just got mine (sleeve hitch though) 65 bucks...and you can still see the paint
Old 03-16-2015, 04:50 PM
gdheck's Avatar
Well crap, I was thinking they were probably 100-125 too high. I guess I'll pass on the 3-point model.
Old 03-17-2015, 02:04 AM
red56turbo's Avatar
Keep your eyes peeled for one. I've seen 'em advertised at $175-$200 before. You can find a nice deal on one every once in awhile. I, myself won't and didn't pay $300 for one either.
Josh
Old 03-17-2015, 12:56 PM
Because it doesn't work exactly the same way as a plow with a Cat 0 hitch on it? If you already have a plow..... why not just make a Cat 0 hitch and weld it on? I'd just run an adapter. It's easy, and works the same. Actually better..... because you can offset the plow exactly where you need it.
Old 03-17-2015, 03:35 PM
cub123's Avatar
cub123 cub123 is offline
The Cat 0 can be offset too, simply loosen the U bolts and slide it where you want it. I've run a sleeve with an adapter, but I prefer the Cat 0 behind a super, It's just a much more robust setup than the sleeve hitch plow IMHO. The prices for them can be crazy, try searching for power king attachments, Ive found some good deals that way.
Old 03-17-2015, 04:08 PM
Yeah..... that's true.
Only difference I see between the plow itself is the bolt flange on the front opposed to the clevis style hitch. Extreme makes the whole set-up. I can't see that the plow is any heavier, just the hitch. I'd just build my own if I wanted a Cat 0. Not arguing...... but I can weld.
