Old 03-30-2015, 10:51 AM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default Flywheel removal tools
Good morning folks, I've got a 12hp 301 and I am down to the flywheel removal. I'm not sure what I need to do next, Please take a look at the picture, I am curious about the small pulley up front, that has the 4 small
screw holes, What do I need to remove it? I have a Puller for the flywheel
but I assume I need to get this off 1st,
Thanks
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 03-30-2015, 12:25 PM
cubs-n-bxrs's Avatar
Daniel1962 I can't tell from the pic but the nut or bolt has to be removed on the pulley with the 4 bolt holes in it. Then you should be able to wiggle or tap the pulley back and forth to remove it. It is located with a dowel pin so it might put up a little resistance coming off. Then you have access to the flywheel. Good luck Kelly
Old 03-30-2015, 12:42 PM
Daniel1962's Avatar
Update with a close up picture, Maybe the little swivel bearing has to come out?
Dave
1964 Cub Cadet 100,
Old 03-30-2015, 01:07 PM
Bearing has to come out and then you'll find a nut behind it that holds the flywheel on the crank. You'll find the service manual in the tech library.
Old 03-30-2015, 01:19 PM
I have never dealt with one that has the swivel bearing in it.
Old 03-30-2015, 01:52 PM
Yep that's how they do the bearing in a QL like a 1200. The 3 pin driver bolts to the four 1/4" bolt holes. You can see it on the Cub parts site, type in 1200 for the model and take a look at the clutch.
Old 03-30-2015, 01:58 PM
Daniel1962's Avatar
How does that swivel bearing come out?
Dave
1964 Cub Cadet 100,
Old 03-30-2015, 02:01 PM
Just like a pilot bearing in a flywheel. It has to be pulled. Slide hammer is the best way.
Old 03-30-2015, 03:45 PM
Terry C's Avatar
Terry C Terry C is offline
On car flywheels I have mostly filled the bearing with grease and found a shaft that fits the bearing ID and hit the shaft with a hammer. You would be using hydrolic pressure to push the bearing out. I don't know if it would work in this application but that's how I remove car flywheel pilot bearings.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-30-2015, 04:01 PM
Terry C's Avatar
Sorry that won't work disregard previous post
Terry
3225
