Old 04-04-2015, 03:32 PM
jimbob200521's Avatar
Default How do I get this *@^@&$ bearing out?
So I took the opportunity to enjoy the gorgeous weather outside and do some Cub work today. After a greasing and washing of the 2284, I turned my attention to the deck. Washed, greased, and installed. It was then I found out that the PTO on the 2284 has a seized bearing So I pulled the PTO and separated the two parts. Now I'm left with a bearing I can't for the life of me get out. Any suggestions guys?
-Ryan
Old 04-04-2015, 03:36 PM
Press.
Old 04-04-2015, 03:40 PM
Berwil's Avatar
Berwil Berwil is offline
2 sockets and a vice. One socket the same diameter, one socket larger diameter. Line em up in the vice, press it out.....unless there is some weird obstruction on the back I can't see.
Bill
Old 04-04-2015, 03:55 PM
Bill
Backside
-Ryan
Old 04-04-2015, 04:02 PM
Berwil's Avatar
Backside
Proceed, put the small socket in from the backside and push out the front. It's not good to push on the inner race of a bearing....except when it's already toast.
Bill
Old 04-04-2015, 04:30 PM
Bill
What he said.
Old 04-04-2015, 04:54 PM
Ryan
Should this repair go bad you may want to look at these guys for a replacement.
http://www.ebay.com/itm/like/2613900...lpid=82&chn=ps
I just bought one from them for an LT2180 and I am impressed. Also I didn't go through Flea Bay, just called them and did the deal over the phone.
Old 04-04-2015, 05:21 PM
Ryan
I think I can walk you through this if you need help send me a PM with your phone # and I'll give you a call. Probably won't call you till tomorrow because it is now cocktail hour.
Old 04-04-2015, 05:26 PM
sbauerz28's Avatar
What I do with bearing like that is press on the inner race like said above. If the outer race come out your good to go. If the inner race presses out and the outer race stays, run a bead of weld around the inside of the outer race. When it cools it will shrink the outer race enough it should knock out easily with a hammer.
Old 04-04-2015, 05:30 PM
Thanks for the help and quick suggestions, guys
I was able to do as suggested and use my bench vice and a socket to push the old one out. Off to Napa and got a new bearing. Yikes are they proud of that part, $26.93 Anyway, came back home, used a piece of PVC the size of the outer race and pushed the new one in with the vice. Reinstalled, hooked things up, and good as new.
Now, I'm off to cocktail hour so I'll have a cold one to celebrate this project completion!
-Ryan
