Old 04-05-2015, 10:53 AM
Imaddy Imaddy is offline
Default 1772 Cutting Deck
Here we go again!
I've just completed a renovation on a 1772 over the other side on the pond and am attempting to fit its cutting deck. I've released the front adjusters but there simply isn't enough play to lift the deck on to the forward facing prongs and line up the rear spring fasteners with the drive belt under tension
I expect I'm doing it incorrectly but haven't an instruction manual to follow.
So, any advice would be most appreciated please.
Ian
Old 04-05-2015, 11:00 AM
Put the deck on and then install the belt. What deck are you working with?
Old 04-05-2015, 11:02 AM
Hi Sam,
how do you get the belt on under tension?
Old 04-05-2015, 11:06 AM
here's the deck prior to me renovating it
Old 04-05-2015, 11:11 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Is the belt the correct length? Here is a chart from the tech section.
http://www.onlycubcadets.net/forum/s...ead.php?t=4633
I'm going to guess you have a 50C deck. Here is the manual.
http://www.onlycubcadets.net/pdf/44-...p%20Manual.pdf
EDIT: That appears to be a 44 or 50C. Looks like the ID tag is on there.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-05-2015, 11:29 AM
Looks like that to me too.
Old 04-05-2015, 11:57 AM
got the deck and belt on, however a few more questions!
Should the drive belt V (narrow side) fit in the deck pulley groove?
Also, despite trailing the PTO prior to fitting the belt, when now engaged it stalls the engine! any ideas please?
Thanks
Ian
Old 04-05-2015, 12:29 PM
Yes. The correct type of belt is considered a "Section B" belt.
Make sure ALL the pulleys and deck spindles are "free travel" with resistance.
Old 04-05-2015, 01:02 PM
Thanks everyone,
Got it sorted and been out for a trial grass cut, which went to plan with the 1772 cutting perfectly. I think I had insufficient revs when I stalled the engine using the PTO, all good now.
Happy days!
Ian
Old 04-05-2015, 01:42 PM
I spoke too soon!
Just went out to move the tractor in to the barn and the glow plug indicator came on and stayed on despite me switching off the started key. I had to disconnect the battery to turn off the light! any ideas?
I guess I can expect a few teething issues since the tractor remained unused since the 90s until I rescued it from a farm barn last year.
