Old 04-07-2015, 04:35 PM
Tomstadler88 Tomstadler88 is offline
Unhappy 1250 Cub Cadet help!!!
Hi everyone,
I recently inherited a 1250 IH cubcadet hydrostatic (75' I think.) it's in ridiculously good shape and obviously well maintained. It sat a my uncles house for 3 years before I was able to pry it away from him. It started right away and purrs like a kitten. The problem- it won't drive. Let me elaborate; it will creep forward a few feet then stop. No reverse. It is 'trying' to move. Checked the hydro fluid; full and pretty clean. I would love to get this gem up and running as it is nearly 15 years older than myself! Is there a tran bypass I'm not seeing? Should I replace hydro filter? It rolled relatively easy when we pushed it a short distance to the trailer. It also rolls when the engine is running. Again it sat for nearly 3 years (or more)
Thanks a bunch!
Old 04-07-2015, 04:37 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Your hydro valves sound like they are bad. I would change them or get them fixed. A hydro fluid and filter change would help also. I know that there is a guy that makes them or something like that on here. Hopefully some one else can help you with that hook up.
I am broke, but I make it work!
Old 04-07-2015, 04:58 PM
First, welcome to OCC.........
The first thing I would check, is to see if there is a broken "spirol pin" at the Hydro Transmission Input Shaft to Drive Shaft Coupler. See image. These are known to break. What is typically seen, is the drive shaft spins normally but the input shaft to the hydro unit either spins slowly due to friction or not at all.
Old 04-07-2015, 08:19 PM
the spirol pin looks to be in good shape (shaft is turning pump)
filter?
oh, and here's a few pics of the beauty
Old 04-07-2015, 08:39 PM
Make sure it keeps turning when you try to move it. You have to look at the pump shaft. If the key is sheared, the driveshaft will always turn.
Old 04-07-2015, 09:09 PM
TheSaturnV's Avatar
You weren't kidding, that thing looks great.
The filter can be seen from the bottom side, coming from the hydro pump, with the top facing the front of the tractor. Hard to miss, unless it's covered in dirt/oil sludge. It looks just like an automotive oil filter but it's not. It's a hydro specific filter and can be found at places like NAPA.
Google your Cub model for the hydro filter number, or someone will be along shortly with the number fresh off the top of their head!
Old 04-07-2015, 09:22 PM
Napa: 1410
Wix: 51410
Old 04-07-2015, 09:48 PM
red211's Avatar
red211 red211 is offline
That is one nice looking Cub for sure. I would lean toward the spirol pin too, but I am far from an expert.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 04-08-2015, 06:48 AM
Your situation will most likely be, the Spirol Pin failure or a plugged Hydro Filter. Either will cause a lack of fluid to travel throughout the Sundstrand Hydraulic Unit.
Old 04-08-2015, 08:12 AM
If its not a broken pin I'd go ahead and change the fluid/filter, seems like when they sit the fluid gels in the filter which causes all sorts of issues.
Pap's 100
Restored 108
1211 Dual Stick
1050
Tags
1250, cub cadet 1250, hydrostatic, transmission
