Last summer when I restored my 1250, I cleaned out the hydrostat or more so the rear end where all the Hytrans fluid sat for years. But I filled it up to where I thought it was full. I've never really gotten to use the tractor alot due to where I was living...on a small lot in a City. But earlier this spring I bought a house out in the country with an acre to mow....well, last weekend I was rolling the yard and when I was about half way done. The rear end felt like it was grabbing, or like something was binding up. I finished my yard and I put the roller away. I've had a small leak coming from that cork gasket where the hydrostat meets the rearend. So, I thought maybe I was low on Hytrans. So, I remove the plug on the rear end and oil starts barreling out. My question is, is it possible that there could be to much Hytrans oil in the rearend? Could/Will that do any harm?
![]() Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978 Columbia City, Indiana |
If you filled it to the filler hole, that would be correct.
When the fluid gets warm, it expands and when taking the plug out when warm, it will seem overfilled. I would suggest checking again with it is cool. a dixie cup amount overfilled, isn't going to hurt anything. |
I checked it after it had been setting for 3 days....I think its fuller then a dixie cup. I'm going to go home today and take the plug out and let it empty out to the level of the plug.
Did it sit outside at all? I'm wondering if water got into the tranny and raised the level on you. I know hytran encapsulates water, but if enough gets in it will change the level. That could cause the jerkiness too, because water would sink to the bottom where the suction tube picks up.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors!
Also, try to park the tractor on a flat surface for your latest drain/fill attempt. (And cold fluid as noted earlier.)
Cub Cadet 129 48" deck - grass mowing 38" deck - backup deck 42" front blade |
I have read some post on here where members are removing the plate on top of the transmission and filling it from there. I would be concerned that would overfill the transmission. I always funnel mine in from the drain plug and periodically pull the funnel, waiting for overflow. Once it stops its overflow, then I replug it and run it for a day or two, then let it cool and pull the plug to recheck and/or top off if needed.
So, I pulled the plug and emptied out what extra was in rear end above the plug line. I went out and mowed this evening and still have the same issue. But what I have noticed is that it only seems to be an issue, the jerkiness as some have put it, is when I am making sharp turns. Could this "jerkiness"/"vibration" possibly be from a worn out wheel bearing on one of the front or rear wheels?
Do you know the history of this tractor or is it a "fairly new" acquisition? Just asking, if you don't know the history, you may want to check that the spider gears haven't been welded in the differential.
Jusst a thought Good luck
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John"
Old cubby I think I remember resto thread but not sure. Anyway, you didn't mention here that you had changed the filter but only the oil. I'm assuming you changed both but wanted to make sure. If so did you use the correct filter? How bad was original oil? Sounds like it might need oil and filter again if it was bad enough to clog filter. It's hard to get all the bad stuff out in one change, might take multiple times and also some flushing with kerosene or diesel fuel
Jerkiness in a hydro is normally due to cavitation
Let me know if this is the wrong stuff. I did some looking around and others have used this. http://www.tractorsupply.com/en/stor...ic-fluid-2-gal
