Old 05-11-2015, 06:27 PM
Rob Ach Rob Ach is offline
Default 129 ?
Have a IH 129, the weekly workhorse, that I was using to mow. I ran over a bit of a tree root, a somewhat significant bump, and the engine just died. The engine still turns over but just won't start. Was thinking maybe a safety switch but the switch to engage the blades seems to be working just fine. There is no spark but that might make sense. Any thoughts on how to begin to troubleshoot this? Any general direction would be greatly appreciated. Thanks in advance.
Newbie Rob
Old 05-11-2015, 06:39 PM
Switch to engage the blades? 129 has mechanical Pto. Do you have a later engine transplant in this? You need positive battery volts to positive side of coil during start and run. Negative side will flash test light during start, doyou have that?
Old 05-11-2015, 06:44 PM
Sorry. The brake pedal that engages a switch behind the gas tank ( won't start without your foot on the brake ) and your absolutely right about the pto for the blades.
Old 05-11-2015, 06:49 PM
First, welcome to OCC.
Sounds like an electrical issue. Click on this link for the Wiring Diagram..... 129
With the Key in the On position, do you have 12V from engine block ground to the (+) of the Ignition Coil...???
Old 05-11-2015, 10:06 PM
Actually, they do have a pto safety switch on the driver's right side as well as the foot pedal safety switch, but I doubt that it went out. You do need to pull back on the deck engagement handle to enable that safety switch! Have you pulled back on it and tried starting?
Old 05-12-2015, 12:02 AM
Using your 12V test light attach the clip to ground, turn the key on and touch the pointed end to the pos side of the coil. It should light up. Turn the key and make the engine turn, it (the test light) should stay on.
Clip on ground, touch pointed end to neg side of coil, turn key to make engine turn. Light should go on and off while engine is turning.
If these requirements are not met, your engine will not run and there is no need to look any further.
Old 05-12-2015, 06:47 PM
So I don't have a light but just used a multimeter
Key on- Ground to (+) side of coil= 12v
Key on- Ground to (-) side of coil = 0v
Key on to start - Ground to (+) side of coil= 12v
Key on to start - Ground to (-) side of coil = 0v
Does this tell me it's the coil then? Thanks for all your help.
Rob
Old 05-13-2015, 11:55 AM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
Did you try to clean or replace the points?
That's the most common ignition issue i have with old engines
Sounds to me like the coil is fine
On the tests that you got 0v you should have done. Ignition on, one wire from meter to negative on coil and other wire to positive on battery. You should get 12v then.
If you wanted to test ohms you could do negative on coil to ground
1961 Original
1962 original w/ fenders and creeper
102
72 w/ fenders and lights
124 w/ sleeve hitch
129 w/ lights
5 mower decks, 2 plow blades, 1snowblower
Old 05-13-2015, 01:15 PM
Tells me that everything on the positive side of the ignition circuit is OK.
Test your Ignition Coil per this....... Test
Old 05-13-2015, 04:10 PM
ironman's Avatar
ironman ironman is online now
Rob
Step #2 - What you see depends on whether the points are open or closed at the particular time you are measuring. If the points are closed, you have a ground coming through the points to the negative side of the coil and will read 0V. If the points are open you will see 12V coming through the coil from the positive side.
Step #4 - What you see will be some positive voltage less than 12V because the voltage is pulsating as the points open and close and the meter can't fluctuate fast enough. A test light would flash on/off at the speed the points open/close.
Steps #1 & 2 - As long as the key is in the on or start position you should always have 12V on the coil positive pole. Off position always 0V.
Incorrect indications on the coil negative pole can be caused by points that are pitted, dirty, shorted, not set correctly, etc. Also your condenser is attached to the negative pole of the coil and to ground on your engine housing. The condenser is a capacitor and is electrically bridged across the points to reduce arcing on the points. If the condenser shorts out it is the same as your points never opening and you will always see 0V on the coil negative pole. On the other hand the condenser can burn out and this will shorten the life of your points.
Test lights are cheap & helpful, pick one up.
