I'm getting ready to replace the cork gasket between my hydro and tranny. 1st time I used a factory gasket. It seemed to have double sided clear tape on it that was old. It leaked. Second time I used some cork gasket material I had that was a little too thick and sealed it with silicone. It leaked. I now have some of the proper thickness quality cork gasket material and will cut my own. Should I seal it? With what? Normally over the years I have wiped a thin layer of #2 form-a-gasket on most gaskets as a sealer. It normally works pretty well. I don't use cork gaskets often except for fuel tanks. I've been told to install cork dry so it can swell like a wine cork. Opinions?
I don`t use cork gaskets anymore. I use neoprene and cut out a replacement. I don`t have issues with them leaking. my .02
When I'm reassembling componets in a "prone to leak" area, I use HYLOMAR sealant. It ain't cheap, but you get what you pay for.
I have replaced several with cork and #2, not a leak one.
Scott |
Scott,
Have been trying to find you. Please contact me at easair@charter.net Dave Deal, near Hickory NC |
