Old 06-19-2015, 10:18 AM
dennisf dennisf is offline
Cool 1572 diesel with broken water pump belt
what is the best way to remove drive shaft to replace belt that drives the alternator and water pump'
Old 06-19-2015, 10:30 AM
CubDieselFan's Avatar
You will have to move the engine forward or the transmission backward. Did you run it hot before you noticed that it had broke?
Old 06-19-2015, 11:08 AM
red56turbo's Avatar
I slide the engine forward. Not a bad job at all. Might be a good time to check the rag joints and drive shaft metal couplers for wear. Since you'll have it apart already, they can be replaced if worn.
Josh
Diesel Cub Cadets...........
Old 06-19-2015, 11:16 AM
yes i did run it about 30 minutes hot before i noticed it, thanks for the info..
Old 06-19-2015, 11:53 AM
That's not good. Hope you didn't cook it.
Old 06-19-2015, 01:47 PM
red56turbo's Avatar
Is the temp gauge working? With the belt gone, the gauge probably would've pegged high pretty fast. Check it over good. Hoping you didn't crack the head.
Josh
Old 06-20-2015, 11:39 AM
I will check it over good, once i moved the engine ahead the belt won't be any problem, thanks again for the info. everyone.
