Old 06-19-2015, 04:12 PM
coinman66 coinman66 is offline
Default Static timing question.
Do you start procedure with S in sight hole during a static timing test? And then followed by what?
Old 06-19-2015, 04:40 PM
timbo2's Avatar
timbo2 timbo2 is offline
Check this out from the tech. section if you haven't-
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
- Tim
Old 06-19-2015, 05:05 PM
Yah I've been reading this, but it doesn't really say to start procedure with S in sight hole?
Old 06-19-2015, 05:15 PM
austin8214's Avatar
Roll it over by hand in the normal direction of rotation. When the meter goes to infinity look for the S. If it is past the hole tighten up the gap. If it has not gotten to the hole yet widen the gap.
Old 06-19-2015, 05:16 PM
jimbob200521's Avatar
Try this one:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
-Ryan
Old 06-19-2015, 05:17 PM
timbo2's Avatar
if the points start to break with the S in the sight whole then you are done. I would back it up abit and see what your VOM does as the S appears in the whole. then adjust from there.
- Tim
Old 06-19-2015, 05:58 PM
Ok. Thank u much!
