Old 07-11-2015, 05:15 PM
Workinprogress Workinprogress is offline
Default Carry all
Had an idea the other day of building a 3pt carry all for my cub. Took some scrap steel and welded things up yesterday.
Also remembered old cheap trailer. Built carry all to fit trailer bed. Still have to shorted the trailer bed but think things will work well.
Old 07-11-2015, 05:17 PM
Photo of trailer on carry all. Will cut down soon.
Old 07-11-2015, 05:34 PM
gt383mag's Avatar
gt383mag gt383mag is offline
looks like a cool setup
Old 07-12-2015, 01:27 AM
Berwil's Avatar
Berwil Berwil is offline
Nice work!
Old 07-12-2015, 09:54 AM
red211's Avatar
red211 red211 is offline
Originally Posted by Berwil View Post
Nice work!
X2 How about a closer pic? This got me thinking about a mounted wood hauler for the winter. I have been loading a wheelbarrow and pushing it into the basement, takes one full one a day. The cubs just rest there in the winter so the 128 might just use something like that. Fill it and back it in right beside stove. I am betting I could haul two days worth on it. Turning a key sounds a lot better than pushing a wheelbarrow!!
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 07-12-2015, 06:24 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
looks like you could use it to move pallets around too.
Old 07-12-2015, 07:39 PM
Great idea. Looks almost like a standard class 2 fork carriage where if it actually was the forks are adjustable side to side, and then wow carrying a pallet if fire wood in at a time would be awesome. Or put the cheap trailer on with a pivot so it can dump, homemade Johnny bucket
Old 07-12-2015, 09:27 PM
Photo looking at connection.
Basically 1.25" square stock with angle iron legs.
Old 07-12-2015, 09:33 PM
The lower pins are mounted to a 3/8 inch thick angle iron which is welded to the square stock.
Yes it fits a pallet and I have already used it to move a empty water tank (built in pallet).
Would have to be a small pile of wood on the pellet for the cub to lift. Also my frame is a little light duty to lift more than a couple hundred pounds.
Old 07-14-2015, 03:57 PM
Olesalt Olesalt is offline
Default mover
that may be used to move some round hay bails to.
