Old 07-19-2015, 08:24 AM
KentuckyCub KentuckyCub is offline
Default Engine blown?
Hello, long time first time here. I bought a cub 1810 off craigslist 4 years ago for $325. Some kid had inherited it from his grandfather and didn't know what he had. It came with extra belts, all manuals, and even the receipts. I had a brutal hilly yard at the time and it worked great. The longer I've owned this mower, the more I appreciated the construction, look, engineering and usability.
Recently I moved to a new home with 1.8acres of grass...so I decided to do a complete service job on the old cub. New oil, plugs, filters, hydro fluid change and filter. Found a small leak in the oil filter line, got them replaced. ran some Lucas gas treatment through her.
Long story short on my fourth lap around the yard a heard a shudder and lost some power. Kicked off the mower headed to the garage. I got there and it's running funny and I look down and see oil under the mower, fairly large amount...I pulled the panel but not the black heat shield to look yet. (Afraid) am I in real trouble? Any chance it's not a blown up Kohler?
Old 07-19-2015, 08:39 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
How much oil is on the dipstick?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-19-2015, 09:08 AM
As an educated guess.........you have a broken connecting rod. You can tell by removing the spark plugs and rotating the engine. The broken rod will result in no pressure on the effected side when you put you finger over the spark plug hole.
Old 07-19-2015, 09:17 AM
I'll try it today. How would that explain the oil everywhere? I'm hoping the new oil line blew or leaked. How much pressure is on the oil system?
I had serviced it just before and had it full to the line. Haven't checked it, but know it's low since it blew out a half quart.
Old 07-19-2015, 09:31 AM
Shrewcub's Avatar
I didn't want to be the bearer of bad news, but Roland is probably correct. The oil is more than likely coming from the hole in the block that the broken rod made. I asked about the oil level to make the it wasn't over full from a bad fuel pump.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 07-19-2015, 09:33 AM
When it's cold, has SAE-30 in it, and WOT .......60 PSI at tops. When hot and running, no lower than 20 PSI.
There is no use of "sugar coating" it or being PC.
Old 07-19-2015, 09:42 AM
I appreciate it, going to pressure wash, fill with oil, tighten the oil lines, fire it up and look for leaks today. Wish me luck.
Any suggestions on replacement engines? I found a few deals on parts Cubs.
Old 07-19-2015, 09:56 AM
Depending on the condition of the tractor you may want to consider a kit like this.
http://www.smallenginewarehouse.com/...tegory=1710970
I'm not endorsing this company just putting it out for you to think about.
I'd do as Roland suggested and pull the spark plugs to see if it goes suck squeeze bang and blow rather that starting it. Hate to see you do more damage if it's fixable. How many hours on the tractor?
Old 07-19-2015, 10:11 AM
Shrewcub's Avatar
I will say I have used one of the SEW engines in my 2072 and am very pleased with it. I also repowered a 782 with a Command and am pleased with it as well. Good luck!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 07-19-2015, 10:13 AM
Well crap. No compression on left cylinder...looks like a trip to the mower store. But I plan to keep this one, buy a parts mower and repair it. That or sell it and get a 1811.
Tags
need advice, new cub, new guy
