Old 08-01-2015, 09:11 AM
R.Parker's Avatar
R.Parker R.Parker is offline
Default Cub 1450
Guys I bought this 1450 with a miss. The previous owner installed new points, condenser, coil, regulator and new head. It misses to beat hell wide open...then it idles down all by its self. I'm leaning towards maybe governor issues. What do you guys think?
Old 08-01-2015, 09:15 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
first thing I'd do is make sure he put the correct coil on it, then make sure he put the wire from the points to the - side of the coil and that the condenser is also hooked to the - side. then check the timing . then I'd run it with the points cover off to see if its arcing the points bad. if it is I'd ohm out the coil , if its bad replace it, if not try a different condenser. if its not arcing the points I'd look at the carb. I see allot of people change mass amount of parts and don't have a clue what they are doing or why. they tend to mess up more than they intended to
Old 08-01-2015, 09:32 AM
R.Parker's Avatar
Part number on coil is 31-1781. I turned it over with the cover off of points it's sparking as it should. I have a in line spark plug checker on it and it lights up like it should. Just don't understand why it idles down by it self at high idle. You can lower the throttle lever back down and raise it back up. It revs back up. Minute later is idling low again.
Old 08-01-2015, 09:35 AM
R.Parker's Avatar
Points and condenser wire are on - side of coil
Old 08-01-2015, 09:38 AM
timbo2's Avatar
timbo2 timbo2 is offline
Next on Don's list was the carb- that's what I would check, fuel starting at the tank.
- Tim
Old 08-01-2015, 09:42 AM
R.Parker's Avatar
It's getting fuel. Had carb apart. Blew air in all port and jets. Pulled needle out..it's all clean and working as it should.
Old 08-01-2015, 09:51 AM
R.Parker's Avatar
And when I say it idles down. The actual governor arm closes thus closing the connector rod to carb...
Old 08-01-2015, 10:42 AM
timbo2's Avatar
Did you remove the welch plugs, soak the carb, run a small wire thru the passages or just spray it? I've done it both ways and the first way is much better.
Set the gov. arm on the cross shaft as shown in the manual?
looked at the valves?
LEt us know all you've tried, more info the better.
- Tim
Old 08-01-2015, 11:02 AM
R.Parker's Avatar
Carb was completely tore down and sprayed with carb cleaner and blown out with air. I havent adjusted the governor arm. Be honest I have never done that nor have a manual to do so.
Old 08-01-2015, 11:06 AM
dvogtvpe's Avatar
so what does it do? idle down on its own or mis or both ?
