Old 08-05-2015, 09:28 AM
jimbob200521's Avatar
Default Is this a viable option for our Kohler Command/Briggs V-Twin engines?
Ran across this this morning and had the idea, check out this product (not new to most people, I'm sure):
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
Could we use something like this on our V-Twin engines (I have a Command in mind)? It'd give us 4 easy taps to install a pressure gauge, oil temp gauge, or anything else applicable we wanted to. Just seems like it'd be an easy solution to adding a couple useful gauges to our machines.
Thoughts gentlemen?
-Ryan
Old 08-05-2015, 04:47 PM
inspectorudy's Avatar
I just put a brass "T" in the oil pressure line and ran one side up to the oil pressure gauge on the dash. It cast about $10 for the parts and about $25 for the gauge. I looked for a gauge that only went to 60 psi but could not find one so I made do with this one. As you can see, I moved the Hobbs meter under the hood since I never look at it while I'm on the mower and it offers no useful info except oil changes etc.
1811 Hydro
Old 08-05-2015, 07:06 PM
Cool setup but I don't think it will play on a Vanguard. The filter is very close to the frame as it is at least on a 1641.
Old 08-05-2015, 09:49 PM
Sam,
I mentioned the Vanguards simply because they are a V-Twin but my main thought was a Command.
I think it'd be great to add the adapter, add an oil temp gauge as well as an oil pressure gauge all from one central adapter/location. Just curious if it's viable or a dumb idea
-Ryan
Old 08-06-2015, 06:54 PM
Group_44's Avatar
Group_44 Group_44 is offline
If your dealing with the Vanguard you can do the almost the same thing using a stock Briggs remote oil filter adaptor. It has two plugs on the adaptor plate. I bought two used 16hp Vanguard engines that had these installed, appears to be a factory part on some models.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 08-14-2015, 02:01 PM
j4c11's Avatar
j4c11 j4c11 is offline
That thing sure looks tempting to get for a Magnum. Plenty of space where the remote filter is and it would be behind the firewall with no lines going across the engine to the oil sentry port where they can melt.
Which size is the correct one?
That also looks like a great option.
