Old 08-22-2015, 02:37 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Default Belt question.
I don't know if i was looking in the right spot of the manual, but i couldn't find it. Does anyone know a good size belt for a 1250 with a 44A deck? It seemed to work very well last year, but seems to have stretched out a bit. i lost a lil bit of grass throw. It just seems to fall out now. Could this be a sign that my PTO is going bad? I am not sure what size belt i got last year. I am maxed out on my adjustment bolt. Any one else deal with this?
I am broke, but I make it work!
Old 08-22-2015, 03:02 PM
It's in the parts book.... for the mower deck.
Yes, belts stretch. Good ones don't stretch as much.
Old 08-22-2015, 03:16 PM
Thank you j. I used a kevlar cub belt from TS. Are these not good? I was using the old belt to compare. At the time, my tractor knowledge was not where it is now. Not thinking that belt would have been stretched out. Thanks again.
Old 08-22-2015, 03:17 PM
i run the kevlar belts from ts with no issue, the ones on my 108 are 4yrs old and still look new.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-22-2015, 07:58 PM
j4c11's Avatar
j4c11 j4c11 is offline
3/8" x 78"
IH-59971-C1
Old 08-22-2015, 09:08 PM
thank you J4c11
Old 08-22-2015, 09:18 PM
timbo2's Avatar
timbo2 timbo2 is offline
That belt is correct if you have the smaller center pulley on your deck. If the pulley is
5" you need 117465-C1 (1 inch longer)
good resource - http://cubfaq.com/belts.html
- Tim
Old 08-22-2015, 09:23 PM
Thank you timbo2
