Old 09-02-2015, 08:47 PM
Willy1215 Willy1215 is offline
Default PTO clutch sleeve?
I bought a used PTO clutch at an auction a while back for my 2082. It works but needed the bearing replaced. I have a new bearing but now realize the sleeve (if that's what it is called) that goes inside the bearing and over the crank shaft was missing. Does anyone know where or if i can get another one? or maybe have some measurements so i could have my buddy turn a new one on his lathe? Any thoughts are appreciated.
thanks
Old 09-02-2015, 09:07 PM
j4c11's Avatar
j4c11 j4c11 is offline
http://www.amazon.com/Boston-Gear-Be...sleeve+bearing
The crankshaft on my M20 was 1.25" in diameter, you may want to verify it's the same on yours. The sleeve is 1.5" long , I don't know the OD.
Old 09-03-2015, 12:14 PM
If your talking about the stepped shoulder spacer that fits between the 2 bearings I doubt that you'll find one alone. If you need to reduce the ID bore of the clutch to fit a smaller shaft that is no big deal.
Old 09-03-2015, 02:18 PM
thanks
Can you use your old one, or did you not have a clutch to take it out of?
Here is what I'm thinking you need but Prolly the dimensions are different, so it will be of little help other than a reference.
http://www.ihcubcadet.com/forum/mess...tml?1331850923
Old 09-03-2015, 02:43 PM
George
That is exactly what I was talking about when I said "stepped shoulder spacer" but you did a better job of explaining it to the OP, well done.
Old 09-04-2015, 05:21 PM
my crankshaft is 1.25" as well, don't have the old clutch to salvage the part from, but the info on the "stepped shoulder spacer" is appreciated. I think i should be able to come up with something to do the job. Thanks for help!
Tags
2082, clutch, pto, sleeve
