Old 09-27-2015, 11:46 AM
Default Need advice on chain
Hey guys.
Needed advice about chainsaw (again) chain.
I'm using my Dad's chainsaw and want to get him a new chain for it. Where should I go for said chain? Are there different types? If so, is there a generic one? Should I just go back to the big box store he got it from (about 10+ years ago?) Also, how do I determine how long it is?
Thanks
Old 09-27-2015, 12:31 PM
Take the old chain to any good chain saw shop, they should be able to hook you up.
Old 09-27-2015, 01:28 PM
What he said^^^^^
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-27-2015, 02:04 PM
There are many different types of chain. Here are some of them.
I think most new saws today come with an anti-kickback chain. They don't kickback as easy as say the chisel chain but they don't cut very well either. The last two saws I bought, I threw the OEM chains away and installed chisel chains. Been using them for years and they seem to work best for me. Gotta' be careful though and hold the saw in such a way that the saw can't come back at you.
Inspect the chain drive sprocket on the saw. If it's worn, it'll wear your new chain.
Old 09-27-2015, 03:05 PM
twoton twoton is offline
Like Sam said, find a good saw shop and they will set you up. I always keep about 3 chains per saw. I used to rotate them through the saw shop as they sharpened for a very reasonable price, until I found one of these;
http://www.amazon.com/dp/B0002ZY1WG/...XR8S1VUE&psc=1
now I sharpen them all myself (In my spare time!, ha ha!) and have some really great cutting saws.
Old 09-27-2015, 06:12 PM
cadzag72 cadzag72 is offline
Harbor freight carries a great little bench-mount chain sharpener, definitely a huge help. I second the chisel chains, anyone with a little experience and using care will be fine.
Ian
Old 09-27-2015, 06:47 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Oregon is the top saw chain manufacturer and is the brand almost all the pros use. As the others said any chain saw or outdoor equipment dealer that sells saws can hook you up with the correct chain.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 09-27-2015, 07:48 PM
I googled "my Dad's chainsaw" and got no hits possibly it has a different name/model? like McCulloch Homelight stihl, etc
And a ruler on the bar will give an approximate bar length.
A Drive pin count would also help, ( the teeth that the sprocket drives, are called "drive pins")or even a picture would be most helpful if it is really old or no name on it
Old 09-27-2015, 08:00 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Like they all said... go to a good saw shop and let them fit a good chisel chain to your saw.. chains that are sold pre cut rarely fit and most of them are the politically correct safety chain.
Jay
Proud owner of the following:
Old 09-27-2015, 08:19 PM
I buy a lot of needs from these ppl.
Their chains are good and inexpensive,and
they also will custom make anything you need.
http://www.cutterschoice.com/shop.aspx
