Old 11-01-2015, 09:22 AM
Default Steering Wheel Removal
In our Technical Library Section, there is a thread on Steering Wheel Removal. Although I have used this procedure several times myself without side effects, there have since been procedures of pulling these wheels that a better.
I would like to update this procedure. What I am looking for is, a method of removal, that the "average guy" can do with some "average tools" at his disposal. Understood, that a puller is needed whether fabricated or bought. The procedure needs to be simple and cost effective.
Please send me (onlycubcadets@yahoo.com) or post here, your suggestions. We will then update this procedure.
Old 11-01-2015, 09:58 AM
ford4150's Avatar
ford4150 ford4150 is offline
Old 11-01-2015, 10:02 AM
danfeste danfeste is offline
After soaking the wheel and if the puller wont budge the wheel, reinstall the nut and tighten very tight. This will break the bond to the shaft by pulling the wheel farther on to the shaft, then try the puller again.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 11-01-2015, 12:06 PM
I've always been a fan of pb blaster or other penetrating oil for a couple days after I remove nut, insert 5/16 bolt inside steering tube, use air hammer with blunt or pointed tip to hammer on top of 5/16 bolt head and with upward pressure at the same time, never had one not come off.
Old 11-01-2015, 12:22 PM
what he said.
Old 11-01-2015, 12:23 PM
what he said.
What who said? Me said?
I do like the other idea of cranking it down more to break the hold on it first, very cool idea danfeste
Old 11-01-2015, 01:31 PM
I've never done it this way but that is the way the local CC garage does it.
Old 11-01-2015, 02:54 PM
sbauerz28's Avatar
This works for me.
Old 11-01-2015, 02:57 PM
Thanks for posting these. I am in the process of removing my steering wheel on my 73. Much obliged!
Old 11-01-2015, 04:04 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I do what Alvy does. I put a piece of 2x4 between each knee and the wheel for upward pressure. That keeps the knees from hurting. I like dans idea too. My uncle told me a long time ago, the best way to loosen a tight fastener is to tighten it first.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
