Getting some time to work on the crown vic. here's a pic of the new lower quarters fitted, still have to fit the rocker and then it will be time to weld.
Pic of the rocker fitted in place.
Up close pic of the seam. When it comes time to weld I will start by plug welding the big holes closed and then weld the seam solid, once the seam is welded I will remove the screws and weld the holes shut. It will probably take the better part of a day to weld this solid without warping it.
Tim great job. That is my favorite Ford.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
How do you make the small holes Tim? With a punch? Or with a spot weld bit? (The ones with a center push pilot that look kind of like a hole saw.)
I have this tool that's a hole punch on one side and the other side steps the metal in so the 2 pieces of metal sit flush with each other.
Cool.
That tool is now on the list of tools I don't have, but want.
Why do you use screws instead of cleco's ?
because i have screws.
i prefer screws because the panels don't always fit together perfect and the screw will draw the 2 pieces together vs having to hold the 2 pieces together while you put the cleco in.
OK, I've been happy using Cleco's on my race cars. That said the fit and finish was not all that critical.
