Old 12-16-2015, 02:26 PM
gkingbing gkingbing is offline
Default 42 inch blade power angle
I have seen mentioned that some folk have used a hydraulic implement lift ram to add power angle to their blades. Because that ram is considerable shorter that those usually used for power angle I am very curious on how to accomplish this. These rams are indeed less expensive than the longer ones which might make the modification affordable. Does anyone have plans or pics on how to fabricate this? Snows on the way!!!! Thanks.
Old 12-16-2015, 03:14 PM
The ram has to connect closer to the pivot point of the plow, the further away from the pivot point you mount it the longer the stroke needs to be to get full movement.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2015, 03:58 PM
The thing you have to watch is the fact that the ram is so much smaller. If you hit anything, it will snap/break the ram easily.
Old 12-16-2015, 08:47 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Look for something from surpluscenter.com
1- 1200 in pieces
1- 1864 in pieces
Old 12-17-2015, 09:29 AM
Default blade ram
Thanks for the feedback...Found the ram brackets for $85 on line and asked them what the diameter is on the bracket rods that support the ram. The prices are decent on that ram source. Am thinking that 1.5" diameter with a 7 inch stroke might do the job....
Old 12-17-2015, 06:19 PM
Default Blade ram cylinder
I was in contact with the surplus center and they need more information than my limited knowledge can provide them.
Would one of you nice folks with a ram please measure it fully retracted from hole to hole center? One person on the forum stated that he used a 1.5" bore and a 7 inch stroke so I will just go with that. Thanks much.
Old 12-17-2015, 10:18 PM
Old Skool Old Skool is offline
I don't know if it will work on a 42" but on my Haban 54" blade I got a cylinder from a John Deere grain head, it's the cylinder that raises the reel. So far it works good and only cost $ 10 plus the hoses.
Old 12-18-2015, 12:54 PM
Here Ya go...
C/C is 13.25" approx.
Old 12-18-2015, 01:54 PM
Default Measurements
Great...is there any way you can measure the hole to hole centers with it fully extended? Thanks
Old 12-18-2015, 02:21 PM
Scratch that 13.25, I'm glad I double checked.
Compressed length C/C 13"
Extended length C/C 20-3/8"
Hole on rod end is 1/2" dia
Hole on cylinder end is 3/4" dia
