Old 02-01-2016, 09:54 PM
homebuilt homebuilt is offline
Default Road trip !!!
well after 4 hours and over 220 miles I have myself a model 2B tiller! its in pretty decent shape, I just need to get a mule drive for the 1250. I am confused a little, everything I've read on here is that I need the lower hoop of the three point to mount the tiller to, but it looks like this is self contained? if anyone can shine a little light on this it would be appreciated.
Old 02-01-2016, 10:17 PM
the gearbox acts as the lower mount.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-01-2016, 10:59 PM
The tiller mounting frame does have holes to attach the lower tiller arms to, however it is recommended that the 3 point lower "U" bracket also be used and the pins should go through all 3 holes on each side.
FWIW, 2 of mine have the lower "U" bracket and the other one does not. I don't notice any difference but I'm sure the ones with the bracket are more stable and sturdy.
Old 02-02-2016, 02:30 PM
Thanks for the feedback. It's much appreciated!
Old 02-03-2016, 09:06 PM
Make sure you get the yellow U bracket and use it. The tiller bounces around enough while working you want to make sure you don't go bending anything by not utilizing it. Tiller gear boxes are a PITA to bend back if you ever are ever unfortunate to bend it. Don't ask me how I know.....
