Old 02-03-2016, 04:21 PM
cubguy's Avatar
cubguy cubguy is offline
Default General cutting deck question
Im refurbishing the 289 48" deck from my 3206 cub. Its solid other than this under piece which is all twisted up. It is in the middle behind the middle blade. Now, im assuming it has something to do with aerodynamics of grass clippings
QUESTION: should I cut this chunck of metal out and call it a day or should I try to reshape it and weld it back in
Nroakes
Cub Cadet 3206
Allis chalmers B112
One big Green tractor
Old 02-03-2016, 04:35 PM
I would cut that section out. Buy a new piece of metal. Shape it to fit. Then weld it up (or have it welded).
Looks like it is part of the "deck baffle" and it does effect the cutting capability.
Old 02-03-2016, 04:44 PM
cubguy's Avatar
Thank you for the reply Roland.
Here is a pic from a different angle
Nroakes
Cub Cadet 3206
Allis chalmers B112
Old 02-03-2016, 05:41 PM
cubguy's Avatar
Cutting new metal
Nroakes
Cub Cadet 3206
Allis chalmers B112
Old 02-03-2016, 06:34 PM
That baffle is available from Cub.
http://www.cubcadet.com/equipment/AR...0-A/0045400002
Old 02-03-2016, 06:58 PM
cubguy's Avatar
Thanks for the help guys. I just couldnt wait for ANOTHER part to come in
This should take care of it
Nroakes
Cub Cadet 3206
Allis chalmers B112
Old 02-03-2016, 08:07 PM
You got grass to cut in February?
Old 02-03-2016, 09:29 PM
cubguy's Avatar
I just got this 3206 last weekend and i'm tying to get it all fixed up asap
Nroakes
Cub Cadet 3206
Allis chalmers B112
Old 02-04-2016, 06:02 AM
I'm not 100% sure if that will work or not. It should look like this.
Old 02-04-2016, 01:46 PM
Leadslingingdaddy's Avatar
That baffle helps to produce vacuum (suction) that stands the blade up...You may need to add more to the refurb there....
