I have a CC 2166 with the 16hp Kohler. It came without a deck and I finally found a 48" three-blade deck in mint condition. The deck came with an unmounted belt-driven Model 292 fan assist blower to help move clippings up to the bagger.
The 16hp pulls the 3-blade deck OK in low grass without the blower installed, but I'm concerned adding the blower, especially if grass is high, might be a strain on the little Kohler. It's unknown what horsepower machine from which the deck came, but most with that 48" are at least 22hp. Thoughts? jack vines |
16 single or a 18 hp twin Kohler pulls a 50" deck just fine, or @ least mine do
ive mowed for years with a 48" deck on a 12hp tractor, you should be fine.
I have a 48 on my 1641..the vanguard doesnt miss a beat
48" deck yes, not sure about the fan assist bagger, it may just be a bit much.
If you're talking about dry glass clippings, I wouldn't see a problem. If you're taking about wet leaves....................
I have a fan assisted bagger on my 3205 with a 21HP Kawi and it does put a little bit of a load when I hit heavy grass.
My 1641 runs a 48" deck effortlessly. Fan assisted bagger, wish I had one!
I'm guessing would run just fine. ![]()
Tankman '95 CCC 1641 Eastern PA USMC |
If J-Mech built your 16 like mine, you are good to go.😀
I don't use my Cub. I just work on it and look at it. So far it's holding up very well. |
I have a 48" deck that I am rebuilding for my 2166. Can you tell me which tractor model that your deck came off of?
Thanks....Wes Thompson |
