Old 07-26-2016, 01:17 PM
wjduggan2000 wjduggan2000 is offline
Default Rewire IHC 782 Repower from KT17 to Mag 18
Hi, not sure if this is the right forum, but new to OCC and would like some help.
I'm repowering a IHC 782 from a KT17 Series 1 to a Mag18. My serial number is 20150594U686135. The engine swap went in fine.
I need help with the wiring harness. The ignition switch is a 725-3026 and the KT17 had two wires, one to the coil and the other to the voltage regulator.
From the old harness I can connect to the middle wire of the voltage regulator.
But, I think I need to install a relay from the ignition switch to the ignition module.
I also have a green oil pressure sensor on the engine.
Here's a couple questions for those of you who have done this that perhaps can help;
1) What type and part number do I need for a relay?
2) can I use my existing ignition switch?
3) is it ok to leave the oil pressure sensor unconnected?
Thanks, Bill
Old 07-26-2016, 02:04 PM
As it was answered in this thread...... http://www.onlycubcadets.net/forum/s...662#post384662
Waiting on you.
Old 07-26-2016, 04:32 PM
Terry C's Avatar
Terry C Terry C is offline
Waiting on you.
Serial number is above if that's what you need.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-26-2016, 05:32 PM
Sorry, didn't see the Serial Number.
All the diagram(s) and data was sent to the E-Mail Address listed in your profile.
Old 07-27-2016, 09:47 AM
Thank you, on my way to getting this running !
Old 07-27-2016, 02:48 PM
SGragg SGragg is offline
Inactive Member
Would either wjduggan2000 or Mr. Bedell send me the same wiring diagram for a M18 into a 782?
My recent 782 purchase (#679037) has a Kohler M18 (#1825206456) in it. Would like to double check the wiring in it to your diagram.
Thanks in advance.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 07-27-2016, 05:21 PM
Check your E-mail Acct that is listed in your profile.
Old 07-28-2016, 08:25 AM
Inactive Member
Got it. Thanks very much!
Stanton
Tags
kt17, m18, rewire
