Old 07-28-2016, 09:12 PM
Bsmith Bsmith is offline
Default New to me....3225 FEL!!!
Well I've gone and joined two new clubs. The 3000 series club and the FEL club.
I have been searching for a loader for about the last six months. I want one to help help with landscaping the property that my wife and I are building a new home on.
So I found this. 3225 with a Kwik-Way loader. The tractor has 560 hours on it. It runs nice and the loader works smoothly and quickly. It has some missing powder coat and some surface rust of the foot rest pan but seems to be mechanically sound with one exception.
The steering is horrible. Probably the worst case of wander I have experienced on a power steering tractor. We have a local hydro shop here that has rebuilt some power steering cylinders for us in the past with good results so this cylinder will be headed their way ASAP.
I have a lot to learn about this series of tractors and the loader as both are a first for me but I am looking forward to it. I need to get some manuals and start studying.
I did add a little old IH to it today by adding a set of wheel weights that I had lying around.
Here are the pics.
Old 07-28-2016, 09:14 PM
Picture two
Old 07-28-2016, 09:15 PM
Picture three
Old 07-28-2016, 09:17 PM
Picture four
Old 07-28-2016, 09:18 PM
Picture five
Old 07-28-2016, 09:20 PM
Picture six
Old 07-28-2016, 09:33 PM
Dirty Steve's Avatar
Congrats!! Nice looking rig you picked up and a hell of a nice heard you have!!!
Old 07-28-2016, 09:37 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Your steering, front axle bushings, pins, spindles, bearings, ball joints... basically anything on that front end will wear out in a hurry with a fel. Not saying loaders are bad, but cub cadet gts and sgt were not built for front loaders. Notice the lack of oem cub cadet brand loaders for gts?
Simply put, your loader will punish that garden tractor same as if you dropped it from a 3 story building on to cured pavement. Good luck, nice looking machine, first i have seen a 3k machine with a loader!
1- 1200 in pieces
1- 1864 in pieces
Old 07-28-2016, 09:49 PM
^^^^ X2
It's not likely the steering cylinder is bad. It's likely that the front end is already shot.
Old 07-29-2016, 08:41 AM
My only issue with FEL's on Cubs is the size of the buckets. OK if your using it to clean out stalls in a horse barn or a little mulch but WAY to big for dirt work.
